2010 Tailwind
Ny El-cykel fra schwinn endnu ikke set i Danmark..
FULL SPECIFICATIONS
* Frameset
o Color(s): White
o Size(s): M-17", 19" / W ? 17"
o Frame: Alloy trekking geometry. Ultra low step-through women's
o Fork: Suntour NEX with 1-piece alloy lower, preload adjust and lock-out
* Drivetrain
o Drivetrain: Shimano Nexus 8-Speed gear hub with Nexus twist shifter
* Components
o Brakes: Shimano Nexus roller rear and alloy LP front
o Saddle: Selle Royale Look-in 3D
o Seat Post: Suspension with micro adjust clamp
* Extras
o Battery: Toshiba SCiB 5Ah 24V Casing compatible with Schwinn Tailwind rack system only
o Extras: Schwinn Tailwind rack, B+M Dyno lights and Basta rear wheel lock, fenders, kickstand
http://www.schwinnbike.com/usa/eng/Prod ... l-Tailwind
2010 Tailwind
- Site Admin
- Tilmeldt: 29 maj 2007 16:10
Re: 2010 Tailwind
Batteriet lades op på ½ time! Men så koster den også $3000 i USA - det bliver nok over 20.000 i Danmark.
/Kjeld
/Kjeld
- Tilmeldt: 09 okt 2009 19:33
Re: 2010 Tailwind
GISP ! det var da noget af en pris..
Ingen grund til at tage den hjem .. andet end i Hellerup måske
CAMPUS er også langt bedre
